AC power and IR features
Hi. So I just received my remote today. Hooray!! This device is really nice and well built. Wish it had better ergonomics, mainly a hump on the back or something, but I’m fine with it.
Anyhow, I haven’t started installing the hardware yet. Just charging the remote first before I tackle my plan of attack. I’m wondering a few things though, which I apologize if these questions have already been answered…
What is the recommended AC adapter for the dock? I honestly thought it was coming with a plug for power, not just a USB cable. Whoops. I’m in the U.S. FYI.
Does the actual remote have a built-in IR emitter? I’m seeing different answers about this online. If so, is that feature not available yet? For instance, can I simply point the remote at my Blu-ray player or whatever device that has a front IR sensor and send commands directly just like the original remote? My Harmony 2400 has this option of course. Can the unfolded be setup with specific signal output configurations?
I plan on hooking a lot more than two IR blasters. I’m hearing something about a weak signal from the dock. Am I going to run into issue using IR splitters? In my opinion, however, people with weak signals might be because they’re powering the dock from an inadequate USB port. Rather than an AC adapter.
Anyways, I’m so excited for this device. Can’t wait to implement it into my setup. Thanks!!
It has, but is not yet usable.
USB-C power input 5V min. 1.5 A.
Perfect. Thank you so much!! I do see the IR feature in the roadmap now. Appreciate the info.
