A cautionary tale
In January I noticed my remote screen was separating / detaching from the aluminium unibody, bulging out at the bottom, near the buttons. Pressing on the screen was causing the running activity to pause, which is how I really noticed it.
I contacted UC customer support and, I have to say, they were very good. In 24 hours Tia sent me a UPS return label. I marked the value as zero on the export documentation since this was a warranty return and I waited.
12 days later Tia got back to me - the remote was fixed, tested and they were sending it back with FedEx.
FedEx did an excellent job as usual and the remote was ready for collection a few days later. So far so good, within two weeks the remote was repaired and sent back to me at no cost, the company supporting the shipment fees both ways.
A few days later FedEx sent me a letter - there was a charge to pay - 88.91£ which was actually more than I paid for the original import. What happened was UC sent the remote back valued at 419€ and, although it was marked in small print as warranty return with no commercial value, HMRC kindly charged me 76.17£ to which FedEx added their own 12.75£ “disbursement fee”.
I contacted FedEx immediately and, after a lot of back and forth, yesterday they got back to me with a rather abrupt answer - the charge was correct, based on UC’s documentation. They could resubmit the documentation on my behalf, with proof of the original purchase, paid import fees etc at a cost of 60£ + VAT to me. Assuming I would get the 88.91 charge cancelled, I would still be 75£ out of the pocket. Or I could open a claim with HMRC directly, but in order to do that I would have to pay the duty in the first place, and then hope that it would get refunded by HMRC. Even if they would, FedEx would of course keep their fee.
And it gets worse. While I did not notice straight away, at some point I realised the physical buttons on the remote, D pad etc were not lit. I assumed it was my settings because I had reset the remote prior to shipping it and then I set it up from scratch once returned but the other day I checked and the backlight was set to 100%. It was not the settings, the backlight was proper dead.
It seemed UC’s team had fixed a problem (the detaching screen) and created another (killed the backlight in the process). I was also left to pay 88.91£ for the privilege and waste my own time now starting a claim with the hope of recouping at least some of that money - if HMRC would please.
Tia initially sent me a rather dry answer when I enquired why did they value this at 419 on the export documentation. I quote
We are required to report all package contents truthfully, by size, material, country of origin, HS code, etc. Your parcel was marked as “return”, with additional info on the invoice:
  • “Customer’s own item returning from warranty inspection, no advancement, no commercial sale”.*
But of course what Tia didn’t bother to check was that she was wrong because the shipment should have been declared under Returned Goods Relief (RGR) or equivalent, with either no commercial value declared for customs purposes (as I did when I returned it), or a clear customs declaration applying the appropriate relief procedure and referencing the original import.
Two days ago I contacted UC’s support team to report the new problem (backlighting) and ask them what are we going to do about it. I also expressed my dissatisfaction with potentially having to send this remote back again - another couple of weeks of Logitech Harmony and then potentially being hit with another 88.91£ VAT should Tia & Co deem fit to ship it back with the same documentation.
Separately, I have requested an amended invoice to reflect the warranty repair with no commercial value since no sale / transfer of ownership has taken place. I also asked the company how were they planning to address the small matter of the 88.91£ charge which was incurred due to their incorrect documentation.
It has been now over 48 hours with no answer from UC and, since the weekend is coming, it will be over 4 days before I hear back from the team. In the meantime I have a “repaired” remote control with no backlight and a 88.91£ charge to pay.
To be clear, I am not sharing this experience to criticise the company. I am first of all warning all of you that, should you have to service your remote, now or in the future, you should address this problem with their customer support upfront. Otherwise be prepared to pay duties again when you receive your remote back. I am sure they have not done this on purpose but, obviously, their “small” team is not familiar with the rules and regulations which, to be fair, vary from country to country and, to make matters worse, they don’t even report the original price paid by the Kickstarter backer for the remote but the current RRP price, resulting in a second, significantly higher, customs charge.
I also have to express my concern with having two hardware issues (although admittedly the backlighting is probably caused by the warranty “repair”) within a couple of months of ownership and the prospect of yet a few more weeks of being without my beautiful and expensive remote control which has just become 88.91£ more expensive. Was this a one off, the screen popping out? Is there a swelling battery underneath? Is that bonding agent not strong enough? Will this happen again? Your guess is as good as mine.
To be continued.
R2 or R3?
My own experience with UC customer service left a lot to be desired and a permanent distaste for both their customer service and another company officer who failed to be responsive or accountable and then publicly responded to a post of mine with misinformation designed to make me look like I was being unreasonable.
However, in their defense, I had a very similar issue with Hammerhead (owned by SRAM) and a bike computer where they gave me a discount code for an upgrade in product but then marked the customs documentation with the MSRP, not what I actually paid resulting in taxes and brokerage charges that were substantially more than what they should have been. They too gave me the runaround multiple times before finally refunding the brokerage fees (although it is up to me to recover the overpaid taxes).
I get the innocent mistake in both cases. Can’t stand the lack of accountability …
I am talking about the brand new, bright and shiny R3 pledged in the Kickstarter campaign. Also, keep in mind, this was not a new purchase or an upgrade but a warranty repair. No transfer of ownership. No sale. No added value. The remote had already been imported and duties had been paid.
My expectation is that people own their mistakes. UC should have simply covered the costs you incurred because of their mistake.
UC (and others) fail to understand the value of good customer experience. Had they done the right thing, your post here (and maybe on reddit or elsewhere) would have been about what a standup company they are. Great product, even better people. That’s worth something, whether it’s your repeat business or someone on the fence between an X2 and an R3 going with UC. They opted for lip service and lack of accountability.
That was the point of the SRAM story … opted for lip service and lack of accountability. I haven’t lifted a finger to encourage people to buy a Karoo instead of a Garmin or Wahoo.
A week has passed, no answer from the customer support team.
Two weeks, still no reply from customer support.
That’s pretty ridiculous.
I suppose they don’t care. Niche market, sales are completed exclusively via Kickstarter, there is zero availability once the Kickstarted campaign is over so there are no sales to hurt, there is zero accountability as this is a “project” rather than a direct sale and you get the long disclaimer before pledging. There is also the matter of the company being based abroad which means that if they just decide to ignore your emails which is what they are doing here there isn’t really much you can do about it - there is no authority to contact and there is no door to knock on to get your money back. So what can one really do other than share his / her experience with other prospective customers?
Is there any UC rep monitoring this forum and reading these threads? Is there any way to contact them directly?
Please don’t speculate and make these assumptions.
There is support mail address (support@unfoldedcircle) and a GitHub software feature and bug tracker for official support by UC but it can take time for an anwser depending on how complicated it is to solve. 2 weeks is not that long even for bigger companies.
This forum and Discord chat are just community channels and no offical suppport channels. Sometimes you get answers by an employee but they are not obligated to do this here. They still read a lot of mesages as sometimes bugs or features that are mentioned in commuinity channels get recognized.
Sorry, @kennymc.c that’s not good enough and that’s giving them an excuse for the fact that they treat customers like crap. Customer service from UC is terrible. My experience with them has been patronizing and condescending, no path for escalation, and arrogance from the CEO.
This is a premium priced product with Lada like customer service.
Marcus and Lutz are great representatives of UC and their participation in GitHub and Discord are saving graces for the customer service experience. But let’s be totally clear, a high degree of usability and support are coming from users and volunteer devs with their integrations, not from UC.
I sent multiple emails to support. Each time I received an automated reply with a ticket number. Nobody got back to me and it has been nearly a month now.
I’m also annoyed by the recurring delays in communication but I wouldn’t call the whole support crap. As you pointed out yourself Lutz and especially Markus have given a lot of insights into the development to make some issues more clear to end users.
We all don’t know how much support requests UC gets via mail but due to the virtually non-existent documentation it’s probably a lot. And we also don’t know how many high priority cases they are.
What UC could defintly improve is giving customers a better understanding how things work and why they need to wait longer. This could be just a simple automated mail that they will come back to you within the next x days.
@reven6e If you got multiple different ticket numbers that might be the reason why you didn’t get an answer. Some support systems even mention this in their mails to not ask for the status as this will slow down the process.
Communication broke down once I complained about the invoice that accompanied the warranty return which led to a new import charge. They had responded within 48 hours before.
They could have apologised, they could have sent me updated paperwork to resubmit it to HMRC, they could have covered the charges since this was entirely their fault. Instead they chose to ignore me. And then there is of course the matter of new hardware problems after the “repair”. So yes, I think I am entirely within rights to jump to conclusions.
My experience was similar to @reven6e … they stopped responding when I asked for an escalation channel because I thought their response to my situation was not satisfactory. With no escalation channel, I tried to DM Marton and he chose not to respond as well.
After being ghosted for weeks, I posted on Discord that their customer service needs to improve if they want to be successful. Marton responded with a misleading and misrepresentative narrative designed solely to make me look unreasonable.
I have no respect for people who aren’t accountable.
Lutz (Head of Hardware) finally posted an update on support response time. They have moved their Kopenhagen office (Discord). Not sure why they weren’t able to auto respond to all their RMA customers in the first place as you don’t need an office to send mails.
I can confirm that Lutz got back to me after about two months of waiting. I got a refund for the duty incurred on the return shipment. I was also offered to have the board sent to replace it myself but, although I confirmed I am happy to DIY, they never got back to me again. Maybe in another couple of months!
I read elsewhere that Support now relies on two people because Tia left the team and they are overwhelmed. I will not make any comments - my intention here was just to share an experience. You make what you will of it.
And another two months later, Marton emailed me — they are finally sending the part, which was indeed delivered by FedEx a few days later.
I contacted them again to ask for instructions on how to dismantle the remote and replace the board. It could be another two months before they get back to me, but at least they do eventually.
If I were to make a guess, they probably don’t have a tutorial for this yet, so they may have to create one — not just for me, but for future owners who decide to follow the same route.
Another guess would be that these replacement parts are in relatively short supply and may be coming from China, which could explain some of the long waiting times for repairs and servicing.
None of this is ideal, but at least they continue to service and support their customers, albeit with very long delays.
Again, we didn’t invest in an established company with a mature retail support network. We invested in a small project which, at this stage, has mostly delivered the hardware and software features that were promised. Given the price we paid through the Kickstarter campaign, I’m willing to accept some compromises.
The support network represents a significant part of the retail price of a product, and we have probably paid considerably more for the hardware and software development than we have for a fully developed retail support infrastructure.
So, for those of you who receive no response from the team when running into hardware issues: be patient. Eventually, they do get back to you. It just takes a long time — not days, not weeks, but months.
You have every right to complain about it, but it’s probably not going to make much difference or speed things up.
I will continue to update you on the progress of this particular repair.
They recently got a new support employee because the other one left the company. That’s probably why you got a answer now and they now go through all open cases.
Fantastic! I just emailed support myself because of an issue I had in the past that was unable to get resolved regarding my device’s battery/charging.
