[[un]Official] Unfolded Circle Android App
Yes, I know it has nothing to do with the app - it was more an expression of general frustration.
Thanks, I didn’t know there was a discord channel - I’ll see if I can find it.
Try this http://unfolded.chat/
Thanks…
Good grief! Discord isn’t for people who like a structured environment - What a mess!
Lol. It’s more like organized chaos
@M.a.S.e
Kudos my friend !
This app is EPIC works great.
Thank you!!
JFYI - my integration reliability problems seem to have gone away after I connected the Dock 3 to a more powerful power supply - the one I was using may have been rated higher than it actually supplied…
Nice! Impressive work. Works great on my OnePlus Open. Got my Remote 3 just over a week ago. Quite the learning curve (several factory resets the first 24 hours), but its running (unfolded) circles around my aging Harmony Elite now.
Nice. Glad you like it and find it useful. Thank you
new release is out with support for media browse. disclaimer - i couldnt fully test as i do not have an integration with media browsing yet, however the code has been implemented accordingly.
For some reason the remote acts slightly different when in dock via the app than what it does held in hand.
One thing that i have noticed.
When i start the activity ‘watch TV’ from the remote held in hand, my Android TV box doesn’t always power on. About a 50/50 success rate.
But when i have the remote in dock and start the ‘Watch TV’ action via the Android app on my phone i have a 100% success rate for powering on the Android TV box.
Really strange (in a positive way)
That is because when the remote is docked it’s wifi is always on. When you take it off the dock the wifi will go out during sleep. When you pick it up it reconnect. And the app reconnect to the remote then. There are tweaks you can do to the remote to ensure wifi stay longer.
Thats not the case here.
I know about the wifi limitations. I’ve learned to always toggle the volume on my AVR before I do any action on the remote.
When the AVR volume responds I know the remote has WiFi connection
I’ve also noticed the app being better in some ways.
I have an issue where sometimes switching between activities ends up with the remote still showing the previous activity as being active, but the app follows correctly. I then have to restart the remote to get it back in sync (I have logged this on the bug tracker).
2 compliments in 1 day… i think i can retire today !!! :stuck_out_tongue:
I always use the app, it works better then the remote itself :sweat_smile:
No issues with empty batteries, no issues with wifi disconnects/connects…
That’s great! Please rate the app in the app store is you liked it.
Hello @M.a.S.e,
the Unfolded Circle Android app is much better to work with than the R3. Thanks for that.
A small enhancement would make it even better for me.
The app always selects the first profile in the list. Since you cannot change the order within the R3, it would be nice if you could set the default startup profile in the app, or if the app would remember the last profile used.
Perhaps something could be done about that. Thanks, Sigi
It can be done, but introduce a coding layer with persistent memory. Can look into it but no promises. My time is currently really tied into my paid apps, I’ll definitely consider this as an enhancement before next release. It’s very doable logically. Just need the time to do so. Thanks for the suggestion and glad you like the app.
MAJOR UPDATE: Version 2.0.0 officially pushed to Google. App has undergone re-write, complete overhaul and MANY MANY MANY hours put into this with love and attention. Changelog below:
UC Remote 2.0 - a MAJOR redesign: faster, cleaner, more capable.
New
- Home-screen widgets for Activities, Media Players and Devices, with live now-playing art and transport controls
- Light, Dark and true-black AMOLED themes, plus a custom accent color that repaints the whole app
- A polished, consistent icon set across every screen
- Auto-reconnect, with a clear prompt to re-pair if a remote drops
Fixed
- Your selected profile now stays put when switching tabs
- Connection indicator no longer flickers while swiping pages
- Smoother page loading, plus display and stability fixes
App was downloaded hundreds of times, Please help by simply rating it at the Google Play Store, it take less then a minute and will help exposure, so much work has been put into redesigning it. Especially on the endless app theme color possibilities. (in settings). In addition, we now have a new website for the app: UC Remote - Unfolded Circle Remote Two & Remote 3 Controller App | MiyaraHub Technologies Feel free to check it out. Also feel free to join my Apps discord: MiyaraHub Technologies
