Hi Eddy How can I send you the log file? It is over 90000 lines.
Hi, I received the logs, thanks, will have a look tomorrow and get back to you.
Instructions on how to update are here
Please let me know if this solves the issue.
Kind regards,
Ed
Hi, Pre-release v0.9.9 is available:
- please read the release notes before you update, quite some changes related to config, input sources and listening modes
- make sure you have a recent backup of your current integration version in case you want to roll back
Hi, Pre-release v0.9.11 is available:
- if v0.9.9 caused you trouble with mediabrowser for TuneIn, Deezer, Tidal, then this pre-release fixes it when you set the new configure option ‘network service navigation’ to ‘legacy’
- Other than that same changes as 0.9.9
