I had assumed these were just firmware issues that would get solved, but now I’m wondering if I have a defective Remote 3
Do sounds and haptics work for others? I’ve confirmed they are on in settings with a volume of 100% (even toggeld them off and on), but nothing happens when I push buttons. What triggers sounds and haptics for you all?
And the button backlight also doesn’t work (ish). I was playing with it and found that as I adjust the brightness some buttons light up at certain brightness and then go off at other brightnesses. And even though the color is set to white, I have a bit of a rainboy of colors. Those buttons that are lit are many different colors. I’m guessing this isn’t expected, but want to confirm
