Sorry for the dumb question!
My IP address on my Emotiva processor ends in 127, the one on the integration ends in 100. Does that matter? Should I change it? Should they match ?
Maybe it has two IPs? One for wifi and the other for ethernet.
My Emotiva does not have wifi, the newer version does. Not sure if you mean the processor had wifi.
you do not need to use the IP .100. that was just a placeholder, replace the IP with the IP of your device.
Speaking of dumb questions, I would like to know how to install the Anthem integration. I have created an IR entity for the MRX720 but am interested in an IP integration for same. Many thanks.
