Sony VPL-VW270ES
Hello Guys, any Idea how can Integrate my Sony Beamer VPL-VW270ES the IR Codes?
I have Learned my Remote 3 the original IR-Codes from original-FB says learned but no Reaction from Remote 3 on the Beamer…
Try an IP integration from this page
There are 2 for Sony projector.
The original Sony Beamer-IR-Remote is a RM-PJ28R…
Please Help me…I need a Step by Step or Picture by Picture direction to Integrate the Beamer for the Remote 3…
@kennymc.c , the author of an IP integration, was faster (again):rofl:
Have you tried the included codes? They are from the exact model you own and should work. But I would also recommend to use the IP integration linked above. You find an installation guide on that site.
I’m Found them, the Sony is now in Funktion with the Remote 3…
