Setup Remote 3 error bluetooth
Hi, I had read that I can setup 5 bluetooth devices. But I got everytime an error of I want setup the second device. I had no free slot.
Regards Michael
Do you have settings, development, preview features and enable multiple ble connections enabled?
I had done this. But I can‘t add BT remote.
I had reset all and start new. But now, I could not connect the Dock anymore. I had reset the dock but no changes. And now I can‘t connect the LG TV remote anymore. Everytime I got error that I should set it in connection mode.
I‘m frustreted. Paid 300€ and nothing work.
The dock has nothing to do with the Bluetooth integration. Connect dock with a cable then it should be discovered by the remote and you can configure WiFi credentials with the web configurator. For some Bluetooth devices you must enable just works.
