Has anyone gotten the discrete power on/off to work with Samsung smart TVs? For me, they all act as a toggle and to make matters worse, even though I have my activities part of the same Activity Group, when I switch from one activity to another it turns off my TV. Anyone have any thoughts (I’m using an R3)?
The Samsung integration has 3 power modes. On. Off. And Toggle.
For activities i wouldnt use the Toggle function since it quickly gets “out of sync” that way.
Hope this helps.
The problem is that “On” and “Off” don’t work - they work just like a toggle if they work at all.
hmm works perfectly on my Samsung OLED 2023 model.
Is your TV newer than 2017?
Here are the codes that work with my S95B
ON
0000 006D 0022 0000 00AC 00AC 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0689
OFF
0000 006D 0022 0000 00AC 00AC 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0689
Yes, I have the Samsung QN65QN90AAFXZA, which is much newer than 2017. I’ll try those discrete codes which were posted. Those codes require communication via IR, right (I was hoping to get it working with the Samsung integration)?
Yes, it’s IR
I’m using a mixture of IR, the Samsung TV integration and the Smartthings integration with my Samsung TV’s. IR for power on and off, the Samsung TV integration for most other things including launching Apps, and the Smartthings integration for discrete HDMI selection as that functionality doesn’t appear to work using the Samsung TV integration
Are you using SmartThings through Home Assistant?
No, I’m using this one from one of the most prolific UC integrations developers: GitHub - mase1981/uc-intg-smartthings: An Unfolded Circle Remote two/3 integration for Smartthings Devices
