Remote3 keeps waking up
My remote keeps randomly waking up and turning the screen on. I have turned the wake up sensitivity to 0 so it’s not vibrations. I’ve looked in the logs and have found this, which might be the cause.
2025-10-30 21:17:51.862343 core NOTICE Enter normal mode: standby in 300s
2025-10-30 21:17:51.857346 systemd-logind INFO Operation ‘sleep’ finished.
2025-10-30 21:17:51.843482 systemd-suspend INFO System returned from sleep state.
2025-10-30 21:17:51.834178 systemd-resolved INFO Clock change detected. Flushing caches.
2025-10-30 21:13:41.914791 systemd-suspend INFO Entering sleep state ‘suspend’…
2025-10-30 21:13:41.794143 systemd-logind NOTICE The system will suspend now!
Something about “Clock change detected“.
Does anyone have any solutions to this?
Have you enabled the Keep Wifi connected setting? This also enables Wake on LAN which could cause unwanted wake ups from other devices. There is also an issue on GitHub which discusses internal reasons why the remote is waking up. Your clock change log messages have not yet been mentioned there. [bug] Possible fix for recurring wakes of remote · Issue #646 · unfoldedcircle/feature-and-bug-tracker · GitHub
known issue with version 2.7.0, the UC team are working on a new firmware update to solve.
