Remote Two Web Configurator no Custom Integration Option
I just got a second hand Remote Two, running version 1.7.14 (latest AFAIK).
When trying to add a custom integration, I can’t find any option for that on the Web Configurator. Where is it?
Thanks for any help.
That’s the latest stable. I never used the stable versions myself.
If you enable beta firmware you can bump to 2.6.12 which is pretty stable on the R2 imo
I encountered this myself yesterday. You need to be on latest R2 beta firmware to be able to use custom integrations.
Thanks to both of you. If I may abuse your kindness, how do I install the beta version?
Inside the web configurator go to settings→ general→ Software Update
There should be a toggle for beta firmware. After toggling reboot and you should be able to download
