Remote freeze for one activity
I have now made some tests for my current problem. It seems that problems only occur for one activity. There the remote freezes as soon display is deactivated. After wake up it takes a lot of time until it reacts again (even to swipe actions) and often I have to perform a restart of remote to get back control.
In that activity I use Google Chromestick (mainly used for Waipu TV).
Do you have an idea what I can do?
Best regards
Duddits
Look in the logs to see what is happ6.
Thanks a lot - but how can I access the log?
Setting, development, logs
Thanks a lot - seems that the Onkyo integration made some trouble. Will see whether my changes help
Does not help. In my last try I got at the time of freeze a lot of these entries:
2026-01-07 21:15:50.487357 +00:00 ui WARN libpng warning: profile matches sRGB but writing iCCP instead
2026-01-07 21:15:50.487041 +00:00 ui WARN libpng warning: known incorrect sRGB profile
You seems to have an unknown format of an icon.
