Remote 3 frequently shows “Try again” after wake-up
I have been observing this for quite a while now, and unfortunately the issue is still there and has become really annoying.
After waking up the Remote 3, network-based commands very frequently fail on the first attempt and I get “Try again”. After pressing it again, the command usually works.
From what I can tell, this mainly seems to affect devices/integrations that communicate over the network. It used to happen occasionally in the past, but nowhere near as frequently as it does now. At the moment it feels like I have to press “Try again” almost every time I pick up the remote after it has been sleeping.
I understand that the remote needs to reconnect to Wi-Fi and/or integration entities after waking up, but from a user perspective this really shouldn’t require an additional button press almost every time. The first command should ideally be queued or automatically retried until the connection is ready.
Is this behaviour still being investigated? Are other users seeing the same thing with the current firmware?
  1. Did you install latest beta firmware as they did a lot for WiFi.
  2. Did you increase the resend time on the remote to 10sec?
Hi Ralf,
thanks. I just checked both points.
I have now updated to firmware 2.11.0.
The resend time was already set to 10 seconds, so I had already been using the maximum setting.
I’ll now test the wake-up behaviour with 2.11.0 and see if the WiFi improvements have fixed the frequent “Try again” issue.
Thanks!
Btw. In settings, development, preview features is an option WiFi watchdog which might help.
am aware of this issue; it always takes a while for the Wi-Fi connection to be established. Try assigning static IP addresses to reduce the wait times.
You cannot set a static IP address directly on the Unfolded Circle remote (Remote Two or Remote 3) or the docking station, as these devices are designed to obtain their network settings exclusively via DHCP.
To assign a permanent, static Wi-Fi address to the remote or docking station nonetheless, you must set up a DHCP reservation in your Wi-Fi router.
Thanks a lot for the suggestion and for taking the time to help!
I already had DHCP reservations / fixed IP addresses configured, and the resend time was also already set to 10 seconds.
The only thing I changed was updating the Remote 3 to firmware 2.11.0. Since the update, the problem has completely disappeared so far. The remote wakes up and network commands work immediately again without the constant “Try again” messages.
So in my case, this pretty clearly confirms that the issue was firmware-related. It also fits with the WiFi/reconnection improvements mentioned for the newer firmware.
Thanks again for your help! :+1:
