Didsable auto-switching that solved the problem for me. Thx👌
I think all the reports here show the same issue. I’ll try to write my suppositions here:
- Problem exists if there is more than one access point broadcasting the same SSID
- It then doesn’t matter if something like “Mesh” is configured or not.
- It is only a problem if more than one of the APs is “visible” to the Remote
- Initially remote connects to one AP (strongest?)
- When reconnecting (e.g. all 5 minutes if “Stay connected” is enabled and remote is set to go to sleep after 5 minutes) remote tries to connect to another AP and the AP failover fails leaving the network connection broken
Currently known fixes are:
- configure the WiFi so that remote is only allowed to connect to one specific AP
- create a separate SSID on the same AP Hardware that is only bound to one single AP
- create a complete separate WiFi network with only one AP and a different SSID
The bahaviour of “switching AP” can be found in the logs where the Mac-address of the APs that the remote tries to connect to is shown.
My suggestion to Unfolded Circle: Try to fix the Wifi driver or add an option to use a fixed AP (probably let us select Mac Address) and not try to automatically switch, if this cannot be fixed in driver
As the Wifi chip firmware is closed source and developed by a third party vendor it’s unlikely they can request features. I’m not sure what you can do on the OS side.
