So, I have tried to map long press for the OK/Enter function under an IR command for an IPTV remote. The long press typically operates as a select button under certain scenarios, but I have tried several things, and it seems it is not working.
So far this is the only outstanding function missing from my ‘Watch TV’ activity and it’s very frustrating. Has anyone had similar issues with the remote IR code for the Formuler IPTV hardware?
Does it work if you map the same command on a short press button? Is it even a dedicated command or the same as ok/enter? If you haven’t mapped any command to a long press action the short press command will just be repeated. The problem is that the delay between each command is longer than with other remotes and devices may handle this as a separate command. The exception are IR devices which support native long press commands.
Yes, I can successfully map the OK/Enter IR code via the dock. It also works as expected when navigating and selecting with a short press.
When I mapped the long press function I just used the original IR code I received with a short press. So, guessing the long press may generate an entirely different code maybe? The key would be getting the timing right via the IR dock to see if it does generate an entirely new IR code, but this might prove difficult.
Long press does not use a different code of your IR code. It is meant to send completely different code like short=ok and long=context menu.
If you a repeated command leave long press empty.
OK so you are saying it would be a different command all together? How would you know which command to send, when the only way I’ve made it work on the original remote is via a long press on the OK/Enter button. I’ll have to possibly try other commands on the original remote once in the sub menu to see if I can figure it out.
Also original remote could send different commands wether you short, long, double press or even how many times you pressed a button before (toggle bit).
Look for the device in other databases like Global Cache. They list all commands separately. The Harmony database leak seems to be still online and there’s a tool to convert codeset straight to UCs csv format: GitHub - zehnm/uc-ir-converter: Converts IR remote code databases into Unfolded Circle Remote / Dock IR code sets · GitHub
Thanks Kenny, I signed up for a Global Cache account and will investigate further. I also found a few more threads on the message board that talks about repeat commands and how to configure by modifying the HEX string. I have a few ideas to try and see if I can map the long press and get it to work.
I’ll post an update if I manage to figure it out.
Graham
So, I managed to figure out the repeat code for a long press of OK/Enter for the Formuler CC hardware. Tried a few values and it seems 6 repeats acts as the select tool under certain menus which was missing from my config.
I managed to have the long press work a few times with the repeat value set as 6 but it stopped working shortly after. I’ll try a few extra things to see if 6 is the magic value.
Thanks for the insights and for the additional info you have both provided. Learing more and more as I dig into these forums.
UPDATE
So, the long press to select is fully functional for my Formuler CC. It was a repeat of 6 that successfully mapped this function. With this key now operational I can say that I have the activities mapped to allow me to control everything perfectly. Thanks Kenny & Ralf for the hints and ideas.
Regards, Graham
