I have 2 docks. One charging dock connected to Wifi and another blaster dock connected to ethernet. Both are on the 0.8.0 firmware. I find that both docks go offline about once a week and i have to reboot them. Anyone else experiencing this and any ideas how to fix?
Habe you tried to add them manually by adding a custom url like described here? https://support.unfoldedcircle.com/hc/en-us/articles/20018912602524-Manually-add-a-Dock-in-the-Web-Configurator
Some routers may have problems to resolve the mDNS .local domain that is used to discover the Dock. You can also use the ip of the remote to access the web configurator if you experience a lot of errors while using the configurator.
No. I can try it but mDNS is active and used by a number of devices in my network so not convinced this is the issue.
Do I need to delete them first and then re-add them ?
No, you can just enter the custom url in the Dock settings.
