Question: What can i use the dock lan port for
I don’t really find any info about the lan port, is it used to power the dock via POE or as an alternative connection to the network (Dock to lan and then remote via Bluetooth to dock ???)
The configurator and core logic lives on the remote. right ?
Stefan
It’s an alternative for wireless connection for now.
Yes, the configurator and the brains of the operations are on the remote.
