Playstation 5 Support?
Is there no Support for playstation 5?
Will be there in future?
No and No. i worked on an integration which i got about 90% of the code done, however due to Sony the integration always failed to register with the PS5 remote play.
you can however control PS5 via IP, or set up MQTT with Home Assistant and expose it back to the remote.
Can you maybe elaborate on the mqtt part?
Can you actually control the ps5 using mqtt and home assistant? I have both running and got my ps5 since two days. I’d really enjoy being able to control the PlayStation using my remote 3, for example when watching Blu-ray.
thanks Andre
no, you can only power on and off the PS5 using MQTT. nothing else is supported.
