Learning commands lets dock restart
Since the latest firmware 2.8.2 i recognize that learning IR-commands the dock reboots each third learning-process.
Learning command 1 and 2 work perfect (green LED goes out, command is learned).
Learning command 3 the dock reboots as if you reconnect to power.
Here’s the latest log:
I cannot confirm.
I learned 5 or 6 in a row. Maybe it depends on the codes.
That’s strange.
I learned from Original-Denon-Remote and each third command brings dock to restart.
LED goes from green (waiting for learning) to “short-red” and after that LED is off but Dock restarts.
After that learning the same code again works perfect.
Problem solved.
I did an factory reset on the Dock 3 and after that IR learning works without any dock-restart.
