I have a Harmony 950 which I will replace by my new Remote 3. In my Harmony I have an Activity for watching TV and the DVR button leads me straight to the overview of all my recordings on my Sunrise TV-Box (Horizon). I don’t know where Logitech got this IR code from becaus even on the original remote from the TV box there is no button that brings you there directly. But it’s very useful.
Is there a possibility to find out the IR code that the Harmony uses? On pages like Remote Central I found nothing.
Thanks for your answer. Is it possible to learn raw IR? Thought it’s only possible to learn codes.
But the problem is solved anyway. I had to change to IR mode completely as IP caused big problems. I think there is a bug in the OS. If I use the TV box over IP, while playback recordings remote 3 is extremely laggy, display does not react and hardware buttons have no function…
