IR Blaster needed
i need a nother IR-Blaster, because the doc3 has no good IR-Signal-length and the IR-Extender is stupid. :slight_smile: So could someone help me and show me where to buy it (germany).
The IR-Booster from Harmony doesn’t work with the doc3.
Thanks for your help!!!
Edit: could i use this? → IR Receiver Extender, Universal IR Repeater with 3.5mm Plug, Infrared Remote Blaster Emitter for 38 to 56KHz AV Devices, STB Boxes: Amazon.de: Electronics & Photo
Have you tried the blaster (puck size)? The smaller extenders are meant to be placed on the device. The blaster should have better coverage.
If you want to use a different device you should look into buying a Broadlink RM4 and use this integration GitHub - JackJPowell/uc-intg-broadlink: Unfolded Circle Integration for Broadlink Devices
It should have similar range than a Harmony Hub and even supports RF.
the blaster (delivered with the doc) is up and running. but i need another one for other devices which are not reachable for the actual blaster. thats my problem. :slight_smile:
thanks for your suggestion, i will take a look on it. but at the moment i think, another blaster is the simplest way.
just for your information: the blaster from amazon (listed in first text) works perfect with dock3 but hasn’t such a long range as the original unfolded blaster.
