I have marantz cinema 30, I guess that will work? Can you share the haas? Definitely need an example
I took it and test it great thanks
i will see of it works thanks
can you tell me why the UC official dennon integration doesnt work for HOES? what’s missing?
You can find the HASS webpage with more explanation here: Denon HEOS - Home Assistant
The Denon app only gives you the functions for AVR control like your receiver. When using HEOS control directly, you can do things such as playing and choosing music from your library, grouping multiroom speakers from HEOS together and choosing HEOS favorites (like favorite radio stations). Hope this helps.
i need testers for HEOS integration, please DM me if interested.
I have not seen it mentioned anywhere on the forums yet, but you wouldn’t happen to own a Reavon BluRay Player would you?
Api looks feasible. If at least 2 more people say that they use this device, I’ll add it to the list. I don’t own it but I can build if others can help test.
HEOS integration is ready: HEOS Multi Audio Integration
Are there any Unraid users? They recently introduced an API to monitor the server: Welcome to Unraid API | Unraid Docs
Amazon has also released developer infos for their new Vega OS that will come with the upcoming FireTV Stick 4k Select: Get started with Vega Developer Tools I think there could be some users that will ask for an integration in the future as it’s not Android based anymore.
New Fire TV are Linux based so there is hope that Bluetooth might still work. They are out in 2 weeks. Perhaps there is a special offer next week during Prime days.
Bluetooth will most likely work but you won’t get any media playback infos.
I used to use UNRaid, since i moved to Synology i have not tested them again… pretty awesome what they are adding tho !!!
hi, the possibility to connect directly my remote 3 to an switchbot hub / hub mini / hub2 would be nice.
i thought if i can connect to my homey i can use the switchbot devices too, but i only see switches and lights within the homey-connection.
eventually someone has a other solution?
more information about switchbot → Switchbot EU - Ihr einfacher Wechsel zu einem Smart Home | SwitchBot EU
nice day to to you all! ![]()
if there will be at least 2 more people asking for switchbot, i can add it to the list.
i use switchbot too😉. Integration would be nice🙏🏼
BR Peter
Switchbot
ok,. now to research if they have an API or better yet existing python code somewhere… no idea what they use. hope not bluetooth lol
the hub is connected via 2.4ghz wlan and some devices from switchbot are connected via wlan too or via bluetooth directly to the hub.
2 years old code… wonder if still work. but promosing. i need to read… this is going to be another blind integration as i do not have device. need someone to help with tests. find me on discord please .unfolded circle server
