How to start for Dummies?
Is there any setup guide for “Dummies”?
I am still struggling with getting my devices configured properly.
On one hand I get devices steered by IR added as ENTITY, but an Apple TV is an INTEGRATION. I can add an Entity directly to page, but I didn’t get it managed with the AppleTV.
With the Logitech Harmony it was so simple:
  1. creating all devices
  2. creating activities by adding devices to the activity
In Remote3 I can add Entities to an Activity, but not my AppleTV (Integration).
Like for all integration you must combine/pair it with the devices. Go to add device, select Apple TV then a setup process is started.
Unfolded circle has some explanations for the integrations. This is for Apple TV: https://support.unfoldedcircle.com/hc/en-us/articles/19479576638620-Apple-TV-integration
There are more articles there. On YouTube the user thrill at published several videos.
For a lot of integrations, like Apple TV, you must see the display as often a pin is displayed or a dialog is shown were you must grant permission.
I feel your pain, I’m going to take slow and do an entity at a time, make sure it works and move to the next. I don’t think I will be able to set this up in one sit.
I was very good with Harmony and found several tricks there but even with my experience it took me around 2 weeks to get used to it. Once you understood the logic of R3 it is really easy. “The first step is always the hardest”
Thanks for your commitment.
I just learned, that INTEGRATIONS seem to be just like some drivers, which are needed, to connect to AppleTV, … . Then these drivers will be used to add a real device (Entity).:see_no_evil_monkey:
But maybe I am still wrong.
I will try to learn…
No you are quite right. On a lot of integrations you can pair several devices and use them. So a comparison with a driver is not bad.
Isn’t the channel called “Thrillcat Cinema Lab”?
Yes it is.
