How to setup default keys without an activity
I like to configure the keys of the remote? I like to configure the Powerbutton or any other key to send my Samsung the Frame from art Mode to power down mode.
How can I do this?
You can’t change the button mapping outside of an activity.
is there a way to have two shutdown sequences? One to switch of the tv completely and a 2nd one to bring the TV into art mode?
No, but what you could try is to remove the tv power off command from the off sequence and then create two macros that include the activity (to have the start and stop command of the activity available) and put the full power off command in the first and the art mode command in the other macro. Then map one macro to the short press power button and the other to the long press power button so the system activity stop command is overwritten.
This dowside of this is maybe some issue with activity group switching.
How can I send a Long press Button command?
The same as you map short press actuons in activities. You can basically map the macros to any buttons. But using both short and long press of the power button is to prevent running the original off sequence.
