So I have an NVIDIA SHIELD TV which looks like the best I can hope for currently is the Android TV integration. Seems to work (basic navigation) but if I want to edit this “entity”, I cant see any obvious way without going through the “Start Integration Setup” again - is this correct?
Seems like bad logic if this is the case.
Also, I mentioned this only gives me basic controls - for example, when using YouTube inside the ShieldTV, you can long press on the enter/OK button on the supplied Shield remote or my existing Harmony, while hovering over a video thumbnail and of course add a video to a playlist/watch later (something I use with regularity) but I cannot see any option in the web configurator to change the function of this battion on the Remote Two from doing anything other than a quick button press (which in the example above just starts the video)
Ideas?
