Anyone with android phone who wants to join a beta test of an app I developed? App will be windows and ios too but beta right now is for android. Some screenshots of the app:
v2.2.0
- Fixed: changing the projector name in setup > Update created new entities and broke activities; the projector now keeps its ID
- Setup > Update starts from your saved settings (leave passwords empty to keep them)
- Setup now tells you when the projector refuses the password, instead of finishing in a state that never works
- Setup shows problems (missing IP, invalid MAC, duplicate name) on the screen and keeps what you typed
- Remote: command sequences (list or comma separated), repeat and delay
Nice work, thank you for the great community work here. Question: would you consider adding ASPECT Ratio control? It is clunky in the standard remote, nested into the menus.
ASPECT setting look like these:
00: Normal
30: Auto
40: Full
50: Zoom
80: Anamorphic
90: Hsqueeze
Having a single key to ‘Anamorphic’ and ‘Normal’ would be godsend for those of us that have anamorphic lenses.
Possibly, sure.
I’m currently focused on finishing and releasing
