So I’m a brand new user, the Remote 3 + dock having been delivered two days ago. I quickly found the LG TV integration by Albaintor on GitHub and it works great, with one exception; it’s missing the “INPUT_SCROLL” command found in the pre-defined IR package. Having several USB drives connected to my TV I use that button/command all the time, so I would very much like to add it into Albaintor’s integration. I also much prefer his screen layout to the pre-defined one.
Is there a way to do this in the web config, or am I stuck with the commands included in the integration unless I actually edit the integration itself (which I have no idea how to do)?
