Convert GlobalCache to Unfolded Circle Upload Format - Quickly Online
This is a working csv posted on Discord: Discord
Here’s one:
@TheWolf
Thats a good example of the output format the code above uses, aka the template the Remote recommends.
I was actually referring to the GC format with the heading changed as per @kennymc.c ’s message that works.
The example @kennymc.c shared above was created exactly like that. Below a link to an older post describing the steps I took to come up with the file:
Don’t have discord so hopefully the post is helpful to others and we can close off this tread. Admin please lock this or something.
This is what might be missing from your process: if you are importing the text file into Excel (or similar) you should select “comma delimited”. This should create a CSV with the columns expected by the remote web configurator.
