Can't find remote 3 version history and release notes
Does anyone have a location for the current software changelog? The unfolded circle website has ancient info. I just updated my remotes to 2.6.3 and searching google for the release notes returns nothing.
see here: https://discord.com/channels/553671366411288576/1253076993566572706
This should really be in the Remote software somewhere. I don’t use and don’t want to use Discord just to be able to refer to the release notes once the update is installed.
There’s a release notes button in the web configurator if there’s an update available.
But not once you’ve updated.
The problem is that the current releases are all beta updates. When the WiFi issues are solved there should be a new stable version that will also be shown on the changelog site. The long period of now new stable versions was never planned and mainly caused by problems with the Bluetooth integration and the already mentioned WiFi issues.
No matter if beta or stable.
The actual Changelog should be visable inside the Web-UI even after a restart.
