Cannot Use ADB. How Launch AndroidTV App w/o market://?
I’m trying to launch a few apps that are not pre-populating in the ‘Input Source’ dropdown. I have seen suggestions that I use ‘market://launch?id={app package name}’, but that does not work. Even entries on the pre-populated list do not work if their commands start with ‘market://’. I think that Android killed that method.
I heard that another way is to use the ADB integration and to enter the command that way. That does not work either. My television is the Sony A95L and you cannot enable ADB unless you enable ‘Wireless debugging’, (the firmware is up to Android 14). I cannot enable ‘Wireless debugging’ unless the TV is connected to WiFi, and I use ethernet.
Is there another way to enter in the commands by using the Android TV integration and the ‘Input source’ command? I tried entering in the app package name directly, (i.e. com.google.android.apps.tv.youtubetv for YouTube TV) and nothing happens.
I’m open to suggestions.
At the moment ADB will be the only other option you have. Do you only have wireless debugging as option? Did you activate USB debugging?
Yes. I can enable USB debugging. Where I am stuck is pairing. During ADB setup, I do not see a pairing code code up on the TV. I do not know how to pair the integration without manually doing it using the Wireless Debugging.
Did you enter MAC and IP of TV?
If everything fails connect once with WiFi and try again.
It doesn’t matter how you connect it; depending on the TV model, an official update could block access to the Android operating system.
Addendum: It works on my TV, but you have to be careful about what you disable on the device via ADB—otherwise, the TV could become unusable.
A question for Ralf: does ADB allow access via Wi-Fi, or is the Pro app required?
I use ADB for most of my device through WiFi. Mostly I had to active only USB debugging on my Nvidia Shield also WiFi debugging and on 2 Android device it was called internet debugging.
On one device I had remove pairing information after that I could pair again.
