Cannot access web configurator
Baffling issue with my Remote 3 here – it’s working properly when I access it from my phone, but if I try to connect to it from my laptop on the same network, it won’t connect. It’s not that it fails to connect properly but instead as if the remote doesn’t exist from the perspective of my laptop.
I’ve restarted the laptop, restarted the remote, changed the PIN. No change. It’s bizarre.
Am I missing something obvious? This is particularly challenging because the mobile interface is not as convenient as desktop (speaking from my life with a Remote Two).
Try IP instead of name.
Thank you. So odd.
Did it work with IP?
