Can 2 IR Balster 3's be used with 1 dock 3?
I tried connecting 2 of the new IR blasters to 1 dock 3, and it seemed to disable both of them. Just wondering whether this configuration is viable?
It will work in near future automatically, a fix will be included in an upcoming update. Right now it works with manual configuration over web configurator.
Thank you for the prompt response @lutz
Hi, is there a list somewhere of things that don’t work now? It’s very frustrating trying to set up things that don’t work yet.
