Apple TV not responding
I have to restart my Apple TV every time for it to connect after the restart it works fine any ideas
Do your remote and Apple TV have a stable network connection? Do you use the „Keep WiFI connected in standby“ or „Prevent sleep“ in activities settings?
Yes network connection is stable and both are on
Not sure if its the same issue but I had similar issues a year ago now. When I looked in my ATV remote settings there were a number of instances of the R3 remote showing (seems ATV added one every time I ran the integration setup for the ATV on the R3. Once I deleted all of the duplicated R3 entries the strange ATV behaviour stopped. As I say this may not be your issue but worth a look / try.
