Hey guys. I am using the AndroidTV integration with my Sony TV. If I go to the AndroidTV entity, the user interface shows the media player along with 4 little boxes on the bottom. If I click on it, it pulls up all of the apps I have downloaded. When creating my Android acivity, I can add the media player but I cannot find a way to get the 4 little boxes back to pull up my apps. Is there a way to do it? If not, is it possible to program the remote to switch from the activity to the AndroidTV entity in my turn on sequence?
The App selector sadly cannot be add to an activity screen. On the other hand it is not so usefull as an Apple TV because Android TV has no option to publish installed Apps. With the command input/source you can start Apps from the GUI. Sometimes you get there a pull down menu with the predefined Apps.
On Discord in the community project HTTP-Request someone posted a custom entity with HDMI and APP commands:
Thanks for the reply. Is it possible to setup the start sequence to have the remote go to the AndroidTV entity after turning on?
