Android tv x 2!
Hello
I still don’t have the option to add Android tv to more than 1 device.
“Major Android TV integration update:
Support multiple Android TV instances and French translation. Contributed by @albaintor, thanks! (#253).”
Go to your current android integration, start the setup and you have option to add a new one.
I can promise that it is working. I have currently an internal integration with 4 Android TV running. Make sure that your remote is on 1.7.13
