FYI, for those who use my integrations (aprox 40 of them)
All of them got updated to the latest framework version, which may resolve some bugs. I am notifying via this thread rather then finding all 40 individual threads per integration.
For those of you using integration manager, you should be notified, for those which are not, note of the new versions on github.
Not all integrations are upgradable via integration manager (only integrations since the last few weeks), so for those who do not support direct upgrade, you will need to re do the setup post upgrade.)
This should solve some bugs, especially for integrations with sensors/entities which became unavailable, among other things.
As a reminder, all my integrations can be found here (should you wonder if you have it or not) :
