Is there a Chance to Move the Activities on Remoute Display Up or Down to new Position…?
In cusomize you remote you see the activities on your remote. Select edit page then you see 6 points right to the activity name click and hold it and drag were you want to.
OK I’m found it, it was easy to use…
