Hello
Would it be possible for the R3 to resume the started activity after a restart?
My wife started the "Watch TV" activity today, then the R3 switched off and the battery was dead. Now it's on again, but it says the activity is OFF!
Is there a solution for this?
no, there is no current auto detect previous status, that being said if you set up your activity sequence correctly, you can just press start again and it will not disrupt as it will detect the current state of the powered on devices and re sync.
Thank you. ![]()
